AF Nikkor 50 mm 1:1.8D
Bought a new camera, lens or accessory? Tell us what you think by writing your own review here!
Postby DavidCurr » Mon Apr 20, 2009 5:28 pm
Great writeup on this great lens. I purchased this lens about a month ago and love it. it has been a great help in my learning how to pay attention to compasition and im taking better pictures as a result with all my lenses.
DavidCurr
Postby bigblocke » Mon Apr 20, 2009 6:54 pm
Thanks hailstorm for the explanation, I think I have I better clue about how things work now...
Probably this lens will land in my hands early this summer, but I am also considering the 50mm f/1,4D AF or the new 50mm f/1,4G AF-S, whats the benefit of purchasing a more expensive one like these? and do these two differ except for the focus speed?
bigblocke
Postby pgtips » Mon Apr 20, 2009 6:59 pm
bigblocke wrote:Probably this lens will land in my hands early this summer, but I am also considering the 50mm f/1,4D AF or the new 50mm f/1,4G AF-S, whats the benefit of purchasing a more expensive one like these? and do these two differ except for the focus speed?
Quoting Ken Rockwell,
Ken Rockwell wrote:The reason you want this new 50mm f/1.4G AF-S instead of the perfectly good 50mm f/1.4 AF-D that Nikon has been making unchanged since 1993 is that you can tweak manual focus simply by touching the ring. With the older AF-D lens, you have to move a switch on the camera to get between manual and auto focus.
Also bear in mind that the Nikon D40, D60, D5000 can only use AF-S lenses and not AF-D ones.
pgtips
Postby michduncg » Wed Apr 22, 2009 9:29 pm
Philip - it's not true that non AF-S lenses won't work with d40/d60 cameras. The lack of focus motor means that the lens will have to be manually focussed of course.
michduncg
Postby michduncg » Thu Apr 23, 2009 10:07 pm
Went out and bought this lens today. Only tested it out in the shop on my D60 but it seems really easy to focus. There is a focus indicator that lights up in the viewfinder which is real handy. You just lock the aperture ring at f1.8 and then use your in-camera aperture controls to set your f-stop. Not had a chance to use it yet though!
michduncg
Postby Dave16 » Sun May 03, 2009 3:56 am
I think you will find you have to set the aperture ring to f22. If you don't, it won't work!
Dave16
Postby bubblewrap » Thu May 27, 2010 1:02 am
Dave is right, the aperture ring has to be locked at F22.
I just got this lens today and im not sure about manual focus override. It autofocuses with my D90 but is it safe to adjust the focus later on manualy?
bubblewrap
Postby Citruspers » Thu May 27, 2010 8:54 am
It is if you flip the AF switch on the body.
Citruspers
Postby JonathanEvers » Tue Jul 13, 2010 12:38 am
I have been torn between this lens because of value for money and the 1.4 AF-S because it will autofocus on my D40.
I have 1 nephew and 2 nieces (twins) all under the age of 6, so I think I would need autofocus.
This is my choice
1) buy the 1.8 AF lens and hope I can focus
2) buy the 1.4 AF-S lens
3) sell my kit and move to the Canon 550D or 50D
As I'm in Brasil I could get a good price for my D40, and then buy the Canon back in England. Currently the Nikon D3000 is selling for £1300 with the standard 18-55 kt lens.
JonathanEvers
Postby Citruspers » Tue Jul 13, 2010 10:04 am
Keep in mind that manual focus with fast lenses is tough on today's SLR's, because we don't see a DOF difference when we get below F/2.8. Meaning, if you shoot at F/1.8, and the object you see is in focus, it might not be because of the limited depth of field.
The focus dot helps a lot, and so does a split-prism screen, but the screen is expensive and only viable if you use fast lenses.
Citruspers
Postby Hailstorm » Thu Jul 22, 2010 5:59 pm
Another "first prime" alternative for the D40 would be the new AF-S 35mm 1:1.8 DX.
Hailstorm
Postby hackmann » Mon Nov 01, 2010 10:56 pm
Well, I am a D90 owner.
In my opinion you should not forget to have this piece in your bag.
Its far the best cheap lens I have. IQ its awsome, fast and light lens.
Only problem its having a tendency to flare easly.
You can check some samples here:
http://www.carloshackmannphotography.co ... 8835_UMetH
http://www.carloshackmannphotography.co ... 2246_2ZkBR
http://www.carloshackmannphotography.co ... 3208_WwvyZ
http://www.carloshackmannphotography.co ... 2544_P6yNp
hackmann
Previous
Return to User Reviews
