Do i-Macs ever need calibrating?
Got a great monitor or looking for one? Getting it calibrated? Discuss it all here!
Postby oldCarlos » Mon Jan 21, 2013 9:02 pm
I was talking with a mate about using the Spyder colour calibrator on my monitor. He went the i-Mac route last year & bought a 27" & he says he won't ever need to colour calibrate his monitor. Something about it being in-built?
Surely every monitor over time (however long that is) will need checking? :?
oldCarlos
Re: Do i-Macs ever need calibrating?
Postby oldCarlos » Fri Jan 25, 2013 10:11 am
Anyone one use i-Mac?
oldCarlos
Postby keystrokesuk » Fri Jan 25, 2013 11:33 am
If he has the same lighting in the room and wears the same reflectivity of clothing when sitting in front of the machine then maybe he would not need to calibrate the monitor. However, thee external factors (clothing and lighting) will to some extent change things. You may also find with auto brightness on things will look different.
To be sure things are the same every time you use a monitor then a calibration tool may help.
Here are some other views on the subject
http://blog.bretedge.com/2010/01/12/the ... conundrum/
http://www.photosbykev.com/wordpress/20 ... libration/
and Apple confirm the ambient light sensor will change things
http://support.apple.com/kb/HT4280
Speedlight SB-700
http://keystrokesukimages.com
keystrokesuk
Postby oldCarlos » Fri Feb 08, 2013 11:18 am
Thanks for the links. 8)
oldCarlos
Return to Displays and calibration
