Zoom lens for A6000
DSLRs, compacts, lenses and flashes. Discuss all things Sony here!
Zoom lens for A6000
Postby dara1982 » Tue Apr 19, 2016 2:30 pm
Any recommendations for a long reach zoom for the sony A6000? Mainly for wildlife.
Thanks
Nikon D90 + AF-S 18-55mm + AF-S 70-300MM F/4.5-5.6G IF-ED
dara1982
Re: Zoom lens for A6000
Postby zackiedawg » Wed Apr 20, 2016 7:47 pm
So far, the longest reach 'native' E-mount lens is the upcoming FE70-300mm F4.5-5.6 G OSS lens...it debuts in a few weeks (May 4) and will give you a respectable 450mm equivalent reach. If you need more, you'll have to switch over to using adapters, which on the A6000 will render the focus pretty slow with just about all adapters except the LA-EA2 and LA-EA4 from Sony, which have their own focus systems built in and doesn't use the camera's focus system...those adapters can be paired with any Alpha A-mount lens like the 70-400mm G, Minolta 300, 400, or 600mm, Sony 500mm, Tamron 150-600mm, etc.
I recently replaced my A6000 with the newer A6300 - on the A6000 I used the FE70-200mm F4 as a primary birding and wildlife lens to back up my DSLR...I've got the 70-300mm lens on order as soon as it comes out, and I've also been using the lighter and smaller LA-EA3 adapter on the A6300 with the Tamron 150-600mm lens and it works pretty well too - but that adapter and lens doesn't work well on the A6000, only on the A6300.
Hope that helps!
Justin Miller
Galleries:
zackiedawg
Postby dara1982 » Sun May 01, 2016 6:17 pm
Thanks Justin. Exactly what I was after!
dara1982
Return to Sony
