FZ 1000
DSLRs, compacts, lenses and flashes. Discuss all things Panasonic here!
FZ 1000
Postby Bruggeling » Mon Sep 29, 2014 12:59 pm
The review states as a negative "Can't switch between regional video frame rates".
I bought one some weeks ago and changing between regions (well between PAL and NTSC) is possible.
Imo, this should be removed from the negatives :wink:
The difference between NTSC and PAL is almost meaningless anyway, these are analog systems.
So if you are using a digital TV, the difference is irrelevant, only the framerates differ, and most (if not all ?) digital TV's will play whatever you throw at them via HDMI. On a computer the difference is irrelevant too.
(so I wonder a bit why you marked this as a negative)
Bruggeling
Return to Panasonic
