LR4, dual core and 50Mb files - will SSD speed things up?
Which platform's best for photography? How much RAM do you really need? Discuss computer hardware here!
Postby MrCliff » Wed Nov 14, 2012 2:52 am
Well, should I buy a SSD or a quad core/mobo? I am pretty happy with my dual core & HDD handling of 40-60Mb D800 files but, wondering if I would see improvement with a SSD. SSD is cheaper than I7 and motherboard.
It is hard not to type SDD.
Photo Taker for ~30 years.
Books: The Art of Photography- Barnbaum, Photographically Speaking- duChemin.
@Clifford Rourke on Twitter, Clifford Rourke on Google Plus
How 2 the signature below?
In your profile signature, click on BBCode ( linked under options ) and read up!
___________________
Visit MrCliff on Flickr
___________________
MrCliff
Re: LR4, dual core and 50Mb files - will SSD speed things up
Postby robbon44 » Wed Nov 14, 2012 7:45 am
I don't think you will see much by way of performance increase unless you are multi tasking with some demanding program's.
I run a quad core with 16gb memory and everything is pretty smooth with LR and circa 20mb files
robbon44
Postby fudge » Wed Nov 14, 2012 12:49 pm
I on the other hand would say that if you have an SSD, you will see a boost. LR will start faster and more importantly i think the file handling will be improved as read / write access will be faster. No back to back comparisons to support that but i have run an SSD for 2 + years now and would not look back
M
Nikon D600
Nikkor AF-S 18-35 f/3.5-4.5G, Nikkor AF-S 28-300 f/3.5-5.6G VR, Nikor AF-S 50 /1.8 G
fudge
Postby Plymer » Wed Nov 14, 2012 1:47 pm
Thing is though fudge, you don't really store gigabytes worth of photos on your SSD... so yes, LR will start faster, and the computer will in general be a lot more responsive, BUT your bigger storage is still going to be a spinning platter unless you're made of money and can afford a few 500+ GB SSDs.
If you do get an SSD, storing your LR catalogue on the SSD itself will help, as with the preview cache. Keep the actual RAWs on a proper hard drive, as LR doesn't actually access those unless it's building previews or exporting JPEGs. The wedding photography forum I belong to did some speed tests and found no noticeable speed increase by storing RAWs on the SSD - max speed was actually using SSD+HDD together, and making sure to render at least standard-sized previews for all your photos on import.
Plymer
Return to Computer hardware and operating systems
